intermittent lack of power
flatoutfred
Post by flatoutfred »
Sometimes my ss feels just like a rocket and the rest of the time it feels like the car is not running at his full potential.
I've pulled the codes and I had a lot of them.
After clearing a few times:
-14 Injector #1 Fuel injector inoperative (Abnormal signal emitted from monitor circuit)
-24 Air control valve Air control valve inoperative (Abnormal
signal produced in monitor circuit)
-33 Vehicle speed sensor Abnormal voltage input entered from
vehicle speed sensor
It feels like the engine is running lean and sometimes there's hesitation under boost.
Mods: intercooler, mbc, desnork, k&n drop-in filter.
Any ideas??
Legacy turbo, desnorkled, intercooled, TD04, Borla catback, urethane mounts, wrx rear brakes.
I'd check your wiring on that # 1 injector, and/or check the resistance of the injector.
You may want to try swapping injectors around and see if the code follows the injector. That will tell you whether you may have a wiring issue or injector issue.
