td04 stock boost the real answer?
Posted: Wed Sep 03, 2008 4:21 am
by RJ93SS
so i have heard on this site 8 psi, 9 psi, and 14 psi. from the reading i have done on nasioc i get 14 psi.
What is the stock boost off of a td04 from a wrx?
Posted: Wed Sep 03, 2008 4:37 am
by 94SS_Canada
14
Posted: Wed Sep 03, 2008 4:40 am
by RJ93SS
and if it is 14, could i just swap solenoids on the turbo's, or should i just get a mbc?
Posted: Wed Sep 03, 2008 4:42 am
by Dr. Gonzo
I just installed one from an 03' and it boosted about 8-9psi using the stock boost solenoid. After using a boost controller I was able to turn it up to 11 psi.
Posted: Wed Sep 03, 2008 4:57 am
by 94SS_Canada
Its 14!
Posted: Wed Sep 03, 2008 5:24 am
by RJ93SS
your running a td04 right calgary kid, what year is it out of?
could there be a difference between years, is it off a 2.0 or 2.5
Posted: Wed Sep 03, 2008 6:09 am
by PhilSine
All I know is that all three TD04's I've put on my 98 OBS that came from WRX's all boost 8 psi. This is the wastegate spring pressure using no boost controller.
Do WRX's have boost controllers that allow them to boost 14 psi?
Posted: Wed Sep 03, 2008 6:11 am
by PhyrraM
PhilSine wrote:All I know is that all three TD04's I've put on my 98 OBS that came from WRX's all boost 8 psi. This is the wastegate spring pressure using no boost controller.
Yes, the same basic setup as a stock SS. A duty-cycle based solinoid that blleds pressure from the wastegate spring. You can vary the boost pressure by changing the duty cycle.
Posted: Wed Sep 03, 2008 12:52 pm
by BXSS
A stock WRX runs about 14psi WITH THE BOOST Solenoid hooked up.
Actuator pressure on a JDM 90* inlet TD04 = 8psi.
Actuator pressure on a US WRX = ?psi (8or9)
Posted: Wed Sep 03, 2008 2:26 pm
by RJ93SS
i love the real examples, so i should be able to hook up stock vacuum hoses and just swap in the td04 and run 8-9 psi all day long right?
Posted: Wed Sep 03, 2008 5:39 pm
Just to note, the boost controller on the turbo legacy is better then the WRX. The WRX uses a bleed type boost controller. Ours uses a boost control solenoid that can completely vent boost pressure back to the intake and allow for quicker spool up.
Posted: Thu Sep 04, 2008 1:08 am
by lucas
i put my td04 on about a month ago and i am still consistently boosting 12-13 psi.
Posted: Thu Sep 04, 2008 4:20 am
by RJ93SS
could we maybe post the year and model of the td04's we are using, maybe that's where our difference comes from?
Posted: Thu Sep 04, 2008 4:26 am
by PhilSine
I have one from an 02 and two from 04's. The one currently on my car is one of from an 04.
Posted: Thu Sep 04, 2008 5:21 am
by 94SS_Canada
But, The TD04 isnt going to boost at 14 if it is directly swapped, obviously
Posted: Sun Sep 07, 2008 1:22 am
by joeWM
slightly off topic,but can you just drop a TD04 turbo into our legacys?
Posted: Sun Sep 07, 2008 1:46 am
by 94SS_Canada
Yes!!^
Well almost except for the inlet, you need to get/make a 90 degree elbow
Posted: Sun Sep 07, 2008 1:52 am
by wrxisthebest
ok.. i myself own a 2003 wrx, i also interned at a Subaru tuning shop
the stock psi on a wrx is 13.8, the wastegate spring is a 7 psi spring.. so if u swap a td04 into the leggy and up the boost ull have to use an mbc to up it anything abouve probably 8 psi due to the leggy's stock BCS...
Posted: Sun Sep 07, 2008 1:56 am
by joeWM
94SS_Canada wrote:Yes!!^
sweet deal i have to start lookin into that.
Posted: Sun Sep 07, 2008 8:10 am
by RJ93SS
thank you to everybody who's posted, much appreciated and will be alot of help to alot of leggy owners. i just, as in 5 min ago got back from my first drive with my new td04 an 06 ic installed. everything seems perfect except i am having the same problem i did before... my b gauge needle shakes like crazy but is hitting 8 10 psi, i dont know if it's the shitty gauge i am using or what but i had the same problem with the vf11.
whatever though, i'm super stoked...except i gotta get up for work at 445, whatever, im stoked. thanks to all the people of the bbs that did write up's on the swap and the guru's that answered my questions when i was stuck. i will do my write sometime soon, with pics
Posted: Sun Sep 07, 2008 8:16 am
by RJ93SS
by the way i have no mbc, td04 out of a 04 rex, and i am not running at intake manifold pressure, turbo outlet pressure set up as stock
Posted: Mon Sep 08, 2008 12:44 pm
by BXSS
lucas wrote:i put my td04 on about a month ago and i am still consistently boosting 12-13 psi.
Is it hooked up to the boost solenoid, or is the boost signal directly connected to the actuator?
My TD04 was a JDM 90* inlet version from a '95 EJ20G GF8, I currently run a TD05-16G & it also boosts 8psi on the actuator....
