compression 2.2?
Posted: Tue Sep 16, 2008 3:27 am
by white91wagon
I was just wondering what the compression should be on a 91 2.2 liter naturally aspirated. I'm thinking of getting a used engine that tests out at 140 psi in all cylinders for like $350. Its guaranteed for 1 year.
thanks
Posted: Tue Sep 16, 2008 4:53 pm
Welcome
That seems a little low based on the numbers I saw and others have seen for the non-turbo motors
http://bbs.legacycentral.org/viewtopic. ... ession+psi
I'd suggest searching and see if you find any other people who have posted similar numbers
Posted: Tue Sep 16, 2008 8:06 pm
by 93forestpearl
My '93 EJ22E was in the mid 140's and had 196k on it before I pulled it. Ran like a champ.
Posted: Tue Sep 16, 2008 8:20 pm
by white91wagon
yeah the engine i have now has 250K on it and runs great, but has a small headgasket leak. All it really does is overheat every once in a while. So not really cost affective to just do head gaskets on the old engine. I think this used engine is my best bet so far.
Posted: Tue Sep 16, 2008 9:09 pm
by 93forestpearl
You could do the headgaskets yourself for much less than $350, but you'd have to be so inclined. If you did it yourself, you could do it for about $100 or so.
Swapping the motor is easier though.
Posted: Wed Sep 17, 2008 2:35 am
by entirelyturbo
140 is okay, but yeah, not spectacular.
A properly-running 2.2 should be in the 170-180 range.
Posted: Fri Sep 19, 2008 12:58 am
by tmarcel
DerFahrer wrote:140 is okay, but yeah, not spectacular.
Keep in mind it depends whose measuring stick that you use. Or rather, an expensive but accurate gauge versus a cheapo model from Pep Boys. The cheap gauges can be off considerably. I'd be more worried about how close each cylinder is to one another, i.e. you test one at 130psi and the other three test 160psi. That would be more alarming.
Posted: Sat Sep 20, 2008 1:49 am
by Matt Monson
Let's also not forget the effects of altitude. We don't have a clue where this guy is because he hasn't filled out his profile in it's entirety.
Up here in Colorado we lose something like 12% because we're at 5000ft. If that engine were tested up here I would consider it healthy enough to run.
As sea level, I consider an Ej22e that is at 150 or higher to be healthy enough as long as there isn't greater than a 5% difference from the highest to the lowest cylinder.
Posted: Mon Sep 22, 2008 4:47 am
by white91wagon
Yeah i live at about 2,200 feet in Washington so 140 on all cylinders shouldn't be 2 bad then. I just got the engine in and it runs fine and dandy. However i am having some trouble gettin my exaust manifolds to seal. I used new gaskets and everything but its still not right. I work at the local NAPA and used good gaskets and everthing. I might see if i can get some thinker ones. So just wondering if there are any tricks.
THanks
Posted: Mon Sep 22, 2008 10:41 pm
by ciper
Are they multilayer steal gaskets?
I just had to remove the exhaust manifold from a WRX because of "good" non oem gaskets :(
Posted: Tue Sep 23, 2008 5:02 pm
by white91wagon
no they weren't. I just ordered the steel ones though. They seem a lot thinker. I don't even know why i tryed those oem ones. They probably would have work fine on new exhaust maifolds, but mine have seen better days.
