R180 fitment, forget axles and driveshaft for a moment
Posted: Tue Sep 16, 2008 10:36 pm
by ciper
R180 rear differential in a Legacy is my goal. I've got the parts and time but would like feedback before digging into the car. Multiple solutions exist for the driveshaft and halfshafts (even with OEM parts) so the only worry is the subframe and "dogbone" mount.
Comments? BTW the Spec B axles are r180 inners with r160 outers
Re: R180 fitment, forget axles and driveshaft for a moment
Posted: Wed Sep 17, 2008 12:58 am
by jake15
the diff will bolt up into your old subframe. i have one in my 90, just switch the studs that go through the xmember from your old diff to the r180.
and i just actually looked underneath a spec B a few weeks ago and noticed the same thing
if only i had noticed that before
Posted: Wed Sep 17, 2008 1:10 am
by ciper
Are you using the DSS axles or?
Thanks for the help. I now know what needs to be done...
Posted: Wed Sep 17, 2008 4:39 am
by 93forestpearl
I was told by a VERY experienced subaru mechanic/hotrodder that you can make hybrid axles at the outer CV joint. This is what I plan on doing.
Also, I thought the R180 had the same length studs off the cover? They look that in pictures. If not, its still an easy swap-over.
I've had a 6mt in my car since '06, and have been planning on an R180 swap. I've just had other things pop up in the mean time.
Posted: Wed Sep 17, 2008 4:15 pm
by jake15
ciper wrote:Are you using the DSS axles or?
nah, i'm just using the stock STi axles... i couldn't talk my bro into giving up the DSS ones
Posted: Wed Sep 17, 2008 11:28 pm
by ciper
Which hubs did you use?
Posted: Thu Sep 18, 2008 4:50 pm
by jake15
04 STi hubs
Posted: Thu Sep 18, 2008 8:57 pm
by 93forestpearl
For some reason I missed that part of your post. I find that very interesting
Also, what a friend did on his swapped GM6 was to re-drill SVX backing plates, and re-drill SVX rotors so he could still use small brakes for winter while keeping the STi hubs.
