Another Mystery Connector
Buffman
Post by Buffman »
While I just happened to read about that fan connector, I remmebered there was a connector left unplugged by the pass side of the car. I went out to investigage to see if it was the fan one.
It's not. Body is gray. It has white with green and white with red on one side, and then black and green on the other side. It connects to the Black box on the ABS pump. Anyone know what this connector is for? Wonder if it's why the ABS light is on.
Plug it in. Ill bet it was unplugged because the ABS relay was getting stuck. If it is you will find out when you connect it.
Buffman
Post by Buffman »
I take it if the relay is getting stuck it's going to effect how the ABS works? Is the relay easily accessible to replace?
1992 Legacy LS Special Wagon..
Ya pull the cover you will see the two relays. I fixed mine with a good smacking.
Buffman
Post by Buffman »
okay, I'll have to take a look at it. Cover you mean the black one that says ABS on it right?
Buffman
Post by Buffman »
what do you know. No More ABS light for now..
Test to see if the abs unit works. Find some gravel or sand or wet grass mud you name it and slam on the brakes see if it works.
Buffman
Post by Buffman »
lol I've been trying, but the brakes suck so bad it's hard to lock them up :)
dude time to do the pads, maybe discs, and grease up the sliders! I can lockup my wheels in a emergency if I have to. I put normal discs all around, ceramic pads in the front, and normal ones in the rear. Flushed the old crap out with synthetic brake fluid, and greased up my sliders and made sure they were all clean, as well as getting a gasket kit (which comes with sldier grease anyways) and replaced most the gaskets except the cyclinder gasket. Awesome what almost $400 can do! :P
Buffman
Post by Buffman »
I just bought the car a week ago. It's been sitting in my driveway. The $300 tires were more important than brakes right now. Brakes are coming
