crappy idle
Posted: Tue Sep 30, 2008 7:42 pm
by lucas
sometimes after i get off the freeway and come to a stop light the car will barely idle, ive tried searching for an answer but have found none. Anyone have an idea?
Posted: Wed Oct 01, 2008 1:33 am
by Imprezive
crappy idle could be so many things, it really sucks to diagnose, you just have to go through the steps. I couldn't figure out why my car sucked at idling, it was throwing all kinds of CEL's for the MAF, o2 sensor, and knock sensor. I did a leak-down test and found out I had a broken valve.
I would suggest check all the engine electronics. i.e the TPS, MAF sensor, IAC, coil pack, ignitor.
Check for vacuum leaks, crappy plug wires, or old spark plugs to.
If everything looks good electronically then you might want to do a leakdown test to see if there is anything internally wrong.
Try harder with your searches, you will find the info. You aren't the first to have a crappy running ej22t
Posted: Wed Oct 01, 2008 4:46 am
by lucas
thanks for you help, its not that the car runs crappy all the time just when it runs on vacuum pressure for a long time.
Posted: Wed Oct 01, 2008 5:25 am
by Imprezive
yeah, mine would run fine during normal driving, but if i stopped it would idle ok for about 5 seconds then just stumble and fall on its face. When the valve transitioned from merely cracked to broken it ran like crap all the time.
Posted: Wed Oct 01, 2008 6:11 am
by lucas
ah bob sagget i was hoping you were gonna say, yeah its no problem just change your pcv valve and it will be fine.
Posted: Thu Oct 02, 2008 3:58 am
by Imprezive
LOL BOB SAGGET! Welcome to the automotive diagnostic world, you have 2 choices; make enough money to have someone else do the work, or find the time to do it yourself
If you need resistance/voltage values for the various sensors and can't find them I might be willing to crack open my stack of legacy FSM's and get you the specs.
