WTB: AC Belt Tensioner/Drive Pulley
Posted: Wed Oct 01, 2008 10:53 pm
by Buffman
The little 4 groove pulley for the AC. Need one with a good bearing in it. Don't need the entire assembly just the pulley assembly.
Matt
Posted: Wed Oct 01, 2008 11:00 pm
by gt2.5turbo
got one pm me your addy and ill give ya a shipping quote
Posted: Thu Oct 16, 2008 12:15 am
by Buffman
anyone else. Apparently don't think gt is going to send me that pulley..
Posted: Fri Oct 17, 2008 3:26 am
by jefferson
It it just has a bad bearing, it is pretty easy to put a new bearing in it and the car would be back on the road.
Jeff
Posted: Fri Oct 17, 2008 4:11 am
by Buffman
I don't suppose you have a part number for that bearing??
Posted: Fri Oct 17, 2008 4:18 am
by jefferson
It will be on the old bearing you take out, such as 6203, 6003, etc. The number will be on the rubber seal.
Jeff
Posted: Fri Oct 17, 2008 1:23 pm
by Buffman
there's no rubber seal on this bearing. Not sure if you've ever look at the bearing assembly on it, but at least on this pulley it's an exposed bearing. Maybe at one time it was sealed, but all the balls (well what's left) are exposed and rusted in place..
Posted: Fri Oct 17, 2008 2:26 pm
by n2x4
I've got several. PM me if interested!
Posted: Fri Oct 17, 2008 3:20 pm
by jefferson
The rubber seal on the back side will also have the number on it. I have taken several apart. I don't know why your front seal is gone other than when the bearing destroyed itself it took out the seal. You should also have a shield in front of the bearing held on with a circlip. Was it gone also?
Jeff
Posted: Sun Oct 19, 2008 8:31 pm
by Buffman
snap ring is still there. I'll have to get it out and see if the bearing can be removed.
Posted: Mon Oct 20, 2008 2:18 am
by Buffman
Lol bearing had no recognizable markings on it. Did get the size . 35mm OD, 15mm ID, and 11mm Thickness. Got one ordered from MSC should be here shortly. Surprisingly it came apart pretty easily with a little force.
Posted: Sat Oct 25, 2008 10:47 pm
by Buffman
got my pulley from gt2.5turbo on thursday. Got a replacement bearing for the other pulley and it was back to normal. put the one I received on as it was pretty much rust free. Just have to do a leak test on the Ac system then fill er up...
