losing water
Posted: Sat Oct 25, 2008 8:37 am
currently i have a small problem with losing water
i currently have no overflow tank bcos of my fmic routing
the rad cap looks pretty old 2
also the car has been up to the h on the temp a couple of times with a blockage in turbo water feed line and broken radiator but now have sorted that out
now i warm the car up to temperature and it overflows a little but goes perfectly fine
and when i stop all the water drain out the overflow line and ends up with no water in the header tank at all
will a dodgy cap do this?
