single stage brake booster on our turbo leg
Posted: Fri Nov 07, 2008 10:47 pm
by flatoutfred
Hey guys! I went to the junkyard yesterday to get a master cylinder (1 1/16 abs), while being there I also bought a single stage brake booster from impreza 93-97.
Before I swap the brake booster, I'd just like to get a little feedback from those who did that switch.
I just feel that a brake booster from a n/a is just not meant to be used in a turbo leg.
Sorry for the poor quality(cell phone)
Posted: Sat Nov 08, 2008 3:16 pm
First, just to use the correct terminology, it's not a single "stage" booster, it is a single diaphragm booster. The one in your car currently is a tandem booster with two diaphragms connected together.
Here are some pics from the tandem booster that shows the inards
http://www.main.experiencetherave.com/s ... kebooster/
http://www.main.experiencetherave.com/s ... kebooster2
As far as the single diaphragm booster, definitely swap it in. It provides much more linear feel and brake modulation.
Posted: Sat Nov 08, 2008 6:50 pm
by Adam West
So is this is "fix" for the different feel one gets after upgrading to larger brakes in our cars?
Really noticeable and proven by physics? Or butt-dyno approved (the soft science <grin>)?
Thanks in advance for the insight.
AW
Posted: Sat Nov 08, 2008 9:40 pm
No it's not the fix for upgrading to larger brakes. That's more a master cylinder issue.
The booster is more just a brake/pedal feel issue.
Are you asking if it's really noticable & proven? Yes it's very noticable....whether it can be proved or not by physics is a little more difficult of a question.
Posted: Sat Nov 08, 2008 11:33 pm
by flatoutfred
Thanks Josh, I promess I'll never use the single stage booster term again. From now on, I will say: Oh, look dear, it seems like a single diaphragm booster.
I'll change the booster and mc tonight or tomorrow and I'l give you feedback.
But still, I don't get why subaru would put the tandem booster in our legacy and in the wrx if the feel is so shity.
Posted: Sun Nov 09, 2008 12:00 am
The main reason is the amount of braking assist that can be generated with the tandem booster vs. the single diaphragm booster. Not everyone likes a firmer pedal or has the leg power to really stop the car in the event they need to jam on the brakes.
I'm sure there's other reasons too....
