Need help with WRX Fronts, Arrggg.....
Posted: Sat Nov 08, 2008 7:38 pm
So as many you probably know, I recently upgraded my brakes to 316mm in the rear and WRX in front with S/S lines all around.
Well, I'm about to pull my hair out. After doing the rears I jumped in and drove around the block. Pedal feel was great and the brakes were responsive.
I then did the fronts. Somehow I have a big air pocket in the system now as it takes three full strokes on the pedal to get it to firm up. This is sitting in the car with the motor off. By full strokes, I mean it pushes all the way down the floor pretty easy. After three strokes or so it firms up and quits moving further towards the floor.
I have an electric vacuum pump I've been using the bleed the brakes. At this point I went ahead and put in some Super Blue so I could tell when the fluid had flushed through. I've bleed all four brakes per the FSM order - RF, LR, LF, RR. I leave the pump running and pulling vacuum and will push on the pedal about 15 times before getting out and refilling the resovoir.
No change.
So I went ahead and decided to really flush the fronts. At this point I have cycled approximately 1 liter of fluid through the pass. and driver's side caliper.
No change.
I leave the pump running and pulling vacuum and will push on the pedal about 15 times before getting out and refilling the resovoir. At this point, my foot hurts.
One thing that didn't hit me until a few minutes ago, when putting the WRX calipers on I noticed that the bleed screw was at the 'bottom' of the caliper and not at the 'top'. But the little L and R on the caliper, or so I thought, indicated me to put install the calipers like that.
So, can someone with WRX fronts go out and verify that the bleed screw is on the low end of the caliper? By low end I mean the caliper is relatively verticle and my bleed screw is on the bottom half.
Could I have done something this stupid and installed the calipers on the wrong sticken' side so I have two big air pockets in the calipers that won't flush?
Any help on this would be greatly appreciated. I'm about to go nuts and my car's been down for two weeks trying to get this sorted out in my spare time. I've never had this much trouble swapping brakes.
I am also open to other suggestions.
No change.
No change.
