Factory single CD player question
tahiti350
Post by tahiti350 »
The Factory singel disc cd palyer I put in the wife's wagon has started acting up. It won't load, disc pushes in part way and just sits there. When you push the disc in it won't grab it to pull it in, and the display stays blank. If I hit the eject, it will eject and if you try to put the disc back in it will keep ejecting it. Sometimes after driving a while it will accept a disc and play normally. Today we drove for about 30 minutes and it never did start working.
Any ideas, or is it FUBAR?
Maybe just to dusty? Get a air compressor and blow it out. See what happens. Might have to remove it and blow it all out. Also try a lens cleaning cd.
jefferson
Post by jefferson »
If yours doesn't start working after cleaning etc. I do have a brand new one I would like to sell. Good luck with yours.
Jeff
tahiti350
Post by tahiti350 »
ericem wrote:Maybe just to dusty? Get a air compressor and blow it out. See what happens. Might have to remove it and blow it all out. Also try a lens cleaning cd.
Hard to run a lens cleaning disc when it won't pull the disc in... I'll try blowing it out....fingers crossed
