interchangeable rocker arms and lifters?
Posted: Mon Nov 10, 2008 1:46 am
i was able to find a rocker set from a 92 legacy wagon at my local junkyard. are these exact or could work with my 91 legacy wagon? both are N/A, and during inspection look the same. i only need the one arm from the intake side.
i was also on the hunt for lifters as im in dieing need of a couple lol. found 3 late model Subaru's, two were 1995 n/a impreza's and one 1996 n/a legacy. i took all the lifters from them seeing that more is better? seems the rocker arms are different from my wagon's own. maybe better? could i get away with just installing these arms or should i just swap heads. its just a simple question maybe even silly
btw i ended up coming back with 56 lifters and both 1992 rocker arm set =D
