sti fuel pump????
Posted: Fri Dec 05, 2008 3:52 am
by TdotSubie
OK, so I'm going to be swapping an EJ22T into my 94 impreza L. I'm pretty sure the stock fuel pump won't be enough. But a stock sti fuel pump should be adequate for a lightly modded EJ22T, right? Also, does any turbo subaru downpipe fit?
Posted: Sat Dec 06, 2008 7:33 pm
by TdotSubie
Nobody knows anything about fuel pumps????
Posted: Sat Dec 06, 2008 8:57 pm
by SLODRIVE
Yes, an STi pump will be more than plenty, that's what I'm going to use.
I think WRX/STi downpipes fit with no problems, I'm sure someone else can chime in on this...
Posted: Tue Dec 09, 2008 12:30 am
by adema2626
WRX/STI dp will work dandy but why spend $125 which everyone seems to think they should charge for them and spend $150 for a Ebay 3in bellmouth dp. Also as he said the STI pump will be plenty but depending on how much your paying you might as well get a brand new walbro 255 fuel pump for about $100 shipped. Just throwing it out there.
Posted: Tue Dec 09, 2008 2:16 am
by asc_up
adema2626 wrote:WRX/STI dp will work dandy but why spend $125 which everyone seems to think they should charge for them and spend $150 for a Ebay 3in bellmouth dp. Also as he said the STI pump will be plenty but depending on how much your paying you might as well get a brand new walbro 255 fuel pump for about $100 shipped. Just throwing it out there.
I agree with both of those statements.
And if you have the EJ22T fuel pump (and it's in good working order) use that over the STi fuel pump. It flows more.
Posted: Wed Dec 10, 2008 7:28 pm
by TdotSubie
Thanks for the advice :)
Posted: Wed Dec 10, 2008 9:25 pm
by 94SS_Canada
Our Stock ones flow better than the STI ones? no way....
Posted: Thu Dec 11, 2008 7:50 pm
by wtdash
94SS_Canada wrote: Our Stock ones flow better than the STI ones? no way....
Rumor is that the the stock EJ22T fuel pump is better than the early USDM WRX, but not the STI....although none of them is in the Walbro league.
Here are some examples of Subie FPs : From HERE
What are the OEM fuel pump sizes?
2002-2005 WRX fuel pump 130 lph
2006-2007 WRX fuel pump 145 lph
2008 WRX fuel pump 155 lph
2004-2007 STi fuel pump 145 lph
2008 STi fuel pump 175 lph
EJ22T fuel pump ~135 lph
list of top feed injector sizes for the 2002-2008 WRX and 2007-2008 STI:
OEM 2002-2005 WRX 420 cc
OEm 2004-2006 STi 535cc
JDM STi "pinks" 550 cc
OEM 2006-2008 WRX 560 cc
OEM 2007-2008 STI 560 cc
EJ22T - 370 cc
Plus an STI FP is cheap on NASIOC...but you'll want the install kit:
Walbro fuel pump install/conv kit: 400-791 (I made it work w/my STI pump, too)
Walbro pump: GSS341
Posted: Thu Dec 11, 2008 8:50 pm
by 94SS_Canada
Great INFO^!
Posted: Thu Dec 11, 2008 9:37 pm
by BXSS
+1!
Posted: Thu Dec 18, 2008 4:20 am
by worunner
I am assuming that the 255 in the walbro's name refers to the amount it pumps, correct?
Posted: Thu Dec 18, 2008 6:35 am
by asc_up
Yes. 255 liters per hour.
Posted: Sun Mar 29, 2009 7:51 pm
by SubaruNation
i just bought the walbro 255 and i need to change it out.
does it matter if i have a full tank of gas in my car or should i wait until i have less in there?
and recommendations on the installation?
thanks,
Posted: Sun Mar 29, 2009 8:56 pm
by SubaruNation
got it figured out
