Check engine light problems
Posted: Tue Dec 09, 2008 2:49 am
by sako
I have a '94 Legacy 2.2T and I am currently having a problem with my CE light but it is also affecting my seatbelt light/chime.
I had my CE light flash every so often and I decided to use http://www.surrealmirage.com/subaru/eng ... #enginetip to read my ecu. After using the black connectors I got my diagnosis, the knock sensor and water temp sensor. So I reset the ecu with the black and green connectors. After I did this, my CE light stayed on and my seatbelt light started to flash. I later found out the chime does not work unless I am reading the codes.
So, I bought the new sensors and changed them.
I read the codes again and reset the ecu. The CE and seat belt light steadily flash even after all this. Chime still only works when I'm checking codes. I have tried the battery dance but no luck.
Has anyone had a similar problem that can help me out?
