Transmission Fitment for a newer legacy
Posted: Sat Dec 13, 2008 6:33 am
by 94SS_Canada
The legacy is a 5 Speed 1999 EJ25 Brighton.
It is a cable actuated clutch.
The Transmission is 1998 2.5 RS transmission with rear diff.
What do i need to make this work?
Re: Transmission Fitment for a newer legacy
Posted: Sat Dec 13, 2008 5:18 pm
by jake15
94SS_Canada wrote:The legacy is a 5 Speed 1999 EJ25 Brighton.
an ej25 brighton? you sure?
you'd need the hydraulic clutch pedal box, clutch fluid resevoir, clutch line, slave cylinder and clutch fork if they did not come on the tranny, rear axles if that diff is a vlsd.
Posted: Sat Dec 13, 2008 8:04 pm
by 94SS_Canada
Dont believe the Diff is VLSD, i do have the pedals laying around somewhere. The legacy is the low level Brighton but with an EJ25 i know it is. Ill head over to pick n pull...
Posted: Mon Dec 15, 2008 6:40 pm
by Suuubaaruu
Wouldnt you also need the rs25 flywheel aswell?
Are the drive axle splines the same too?
and what is the FD?
Would you need the rear diff aswell?
Posted: Mon Dec 15, 2008 10:16 pm
by n2x4
jake15 wrote: you'd need the hydraulic clutch pedal box, clutch fluid resevoir, clutch line, slave cylinder and clutch fork if they did not come on the tranny, rear axles if that diff is a vlsd.
You'd need all of that if you wished to switch over to a hydro clutch setup. You don't have to though. You could just swap out the clutch fork and cable bracket between the transmissions and call it a day.
Posted: Mon Dec 15, 2008 10:18 pm
by n2x4
Suuubaaruu wrote:Wouldnt you also need the rs25 flywheel aswell?
and what is the FD?
no
yes
legacy final drive is 3.90, 98 rs is 4.11
yes, you'd need the rear diff too.
Posted: Mon Dec 15, 2008 11:26 pm
by 94SS_Canada
i thought that may have been as possibility. But hydraulic is so much better. However i do i go about it?
Posted: Tue Dec 16, 2008 2:22 pm
by n2x4
Not sure I understand your last question. Can you clarify?
Posted: Tue Dec 16, 2008 3:56 pm
by 94SS_Canada
i thought keeping it a cable clutch would be a possibility....
so exactly how do i go about doing it?
