wtb: 91-94 turbo legacy engine wiring harness
T-lego
Post by T-lego »
im looking for a 92 turbo legacy engine wiring harness some of the connectors on mine broke off for the cam sensors and I'm not sure where they attach so i'm looking at replacing the harness.
PhyrraM
Post by PhyrraM »
Are the broken connectors on the engine side or the bulkhead side of the harness?
If they are broke on the engine side, both the cam and crank sensors are one piece on the engine side, so just replace the sensors.
If you need to replace the bulkhead harness, you need to state weather it's a '91 or '92-'94, sedan or wagon, and auto or manual. Techically all those are different harnesses, although I *think* a wagon harness will work in a sedan as long as both are compatable years and transmissions.
Also if you don't mind unwrapping and re-wrapping the harness, the cam and crank sensor wires are the same as on a N/A harness. So just replacing the needed wires is an option.
T-lego
Post by T-lego »
i have a 92 turbo legacy with an automatic sedan. The connectors on the bulkhead side broke if that's what you want to call it. my local wrecking yard has a 91 turbo legacy i was thinking about garbing the harness from but you say it wont work.
