Hopefully this will be of use.
EDIT: Orig. listed as 440cc injectors.
I intend to install Yellow-top 480cc injectors from a JDM WRX/STi EJ20k so I can get the TD04 chip from Revtronix.com.
I initially thought I needed the '92-94 EJ22 rails and I bought a set of '94 EJ18 rails (same as '92-94's) to have just in case, but thanks to 555BCTurbo & livestrong14 I discovered the stock rails WILL work.
Also, the '90 EJ22 (AT) rails are identical to the '91 EJ22T rails. Legacy777 dropped that hint, as well.
Edit - 11-2010: According to this
POSTthe '90-91 AT rails ARE NOT the same as the EJ22T rails.
Edit/Update: '93 EJ22T rails and injectors appear identical to '91 EJ22T, but haven't determined which years use the metal washers above and below the bolts that hold the rails down... but they were on the '90 EJ22 and '91 EJ22T, and '93 EJ22T
All 4 injectors:
480s/'90 EJ22/'91 EJ22T/'94 EJ18
Injectors in rails - bottoms up
Injectors with rails - tops
Left to Right: 480s, '90 EJ22 (AT), '91 EJ22T, '94 EJ18
Injectors with rails - bottom
And just for grins, here's the 480cc Injectors' flow test.
and Injectors' flow test ohms/volts (Edit: They are 480 Yellow injectors, not 440s - tester wrote what I told them which was wrong.)
