Rockland County NY, 94 Legacy SS 5spd Transmission
Posted: Tue Jan 06, 2009 5:17 pm
I have a 5spd Legacy SS transmission.
100 bux!
Catch is it needs work, I split the case to inspect it. It needs synchros and a 3-4 gear set the gears themselves are fine its the little knubbies on the gear were the syncro hub engages are a bit rounded, might be able to get away with just new synchros and bearings, I did not press the shafts apart and no I wont put it back together.
I have all the parts come and take it away!
This trans is hard to find.
I dont check here often, email munkisd at g mail dot com.
100 bux!
