F/S diamond coil pack, t-leg ecu, cam/crank sensors prce drp
Posted: Mon Feb 02, 2009 2:58 pm
by 94legacy2.2
All was pulled from a running motor yesterday.
I also have about 5 Ignitor packs out of running cars (listed below)
2-Cam sensor 13.00 shipped (1 sold)
Crank sensor 13.00 shipped
4-Diamond coil pack 35.00 shipped (1 sold)
5 ignitor pack 12.00 shipped
spark plug wires (10k) 20.00 shipped
93 t-leg ecu (came from auto, can work in mtx) 90.00 shipped
I can combine parts and do a better deal.
let me know
Tyson
Pictures on request
Posted: Mon Feb 02, 2009 9:03 pm
by Mattheww044
oooooo.... interested in ECU. If nobody jumps on it, ill try to get some money together. Might be awhile tho. GL on sales and ill let you know when i can get it
Posted: Mon Feb 02, 2009 11:55 pm
by Saskatoon Subaru
what kinda price can you do for the coil pack + cam sensor to S7J 4G1
Posted: Tue Feb 03, 2009 3:10 am
by 94legacy2.2
hows 65.00 shipped to your door? Im not sure where your located but the map says Canada. is this correct?
Posted: Tue Feb 03, 2009 5:41 am
by Saskatoon Subaru
Sounds good i'll pm you shipping details
Posted: Tue Feb 03, 2009 2:50 pm
by 94legacy2.2
PM sent Chris.
Once payment clears I can have it in the mail within a day
Posted: Sat Feb 07, 2009 3:43 am
by 94legacy2.2
Chris your parts have been shipped.
List updated
BUMP for more sells
Posted: Sat Feb 21, 2009 6:14 am
by 94legacy2.2
bump
Best offer
Posted: Sun Feb 22, 2009 4:43 am
by 93Leg-c
Interested in the crank and cam sensors. Are they from a T-leg? (just wanted to make sure) From what year engine and how many miles on them? Thanks! :D
Posted: Sun Feb 22, 2009 4:57 am
by 94legacy2.2
The cam and crank sensors are the same between the t-legs and l series.
Engine is 95 I believe. I have so many.
all tested out on the t-leg and all work just fine.
Miles are unknown because Ive had them for sometime now.
Posted: Sun Feb 22, 2009 6:33 am
by 93Leg-c
94legacy2.2 wrote:The cam and crank sensors are the same between the t-legs and l series.
Hmmm, I know the cam sensors are different on my "L" and my ss. The one on my "L" is just the sensor with the wiring connector coming out of it at a 90 degree angle, whereas the ss's sensor has a wire attached to it that goes under the intake manifold somewhere. Can you provide pics of the sensors?
Posted: Sun Feb 22, 2009 2:42 pm
by 94legacy2.2
The "L" series might have been upgraded to the newer style cam sensor then. alot of older subaru's have done this.
Ill snap pictures tonight and pictures of the one on my SS.
Posted: Mon Feb 23, 2009 2:36 am
by 94legacy2.2
ok I have pictures
So both sensors do the same, they are indeed different. Im actually using a "L" ej22e crank sensor and a ej22t cam sensor with no problems. I remember swithcing them out last year when I found my wiring all messed up with both sensors.
Here is a picture of both cam and crank. They do have different colored connectors but they are the same plug between the "L" and SS
Posted: Sun Mar 01, 2009 6:20 am
by 94legacy2.2
bump
Prices arent solid. OBO need parts gone
Posted: Fri Mar 06, 2009 3:44 pm
by 94legacy2.2
bump, lowered prices again
