Oem Keyless entry?
Posted: Mon Feb 02, 2009 5:57 pm
by Tommio RS
Ok. Im wondering if i can use a oem subaru keyless entry system on my 1993 Legacy Turbo. I do know i will need an acctuator to make everthing work smoothly. I am thinking of using a 2000ish legacy module and remotes and really i dont care about what the remotes look like. I just DONT want aftermarket crap.
Thanks!
Posted: Mon Feb 02, 2009 9:01 pm
by magicmike
the oem modules back then were made by alpine. and inegrate withe factory harnesses for those years only. Don't bother. Go buy a DEI ("your valet") unit and an actuator and call it a day. It will even have an output for a starterkill relay.
Posted: Mon Feb 02, 2009 10:08 pm
by Tommio RS
Ok. So then ill need some aftermarket system and the accuator. Any good makes out there? Im not after an alarm, i just want the car to unlock and lock!
Here is a link to one:
http://www.slickcar.com/productdetails. ... uctID=2208
Posted: Mon Feb 02, 2009 10:26 pm
by magicmike
I just told you that DEI is the best bet and wont give you any trouble.
Posted: Mon Feb 02, 2009 10:32 pm
by Tommio RS
what be dei? A brand of sorts. Thats my best guess
Posted: Mon Feb 02, 2009 10:34 pm
by magicmike
second link from google search...
directed elactonics inc
http://www.hornetcarsecurity.com/Produc ... ductID=811
Posted: Mon Feb 02, 2009 10:37 pm
by Tommio RS
Dam... I suck....That never happened....
Posted: Sun Mar 01, 2009 1:55 am
by carsucharda
back in the day subaru used their own branded version of a code alarm system. but it was not plug and play so there is no real advantage other than your remote saying subaru. my code alarm system came with the car (no remotes) it was FORD BRANDED !!! but it works. the door has an actuator shoddily attached to the driver door. it does work but if you are going to buy a system i would not recommend it.
