winter is ending, My warm weather problem!
Posted: Mon Feb 02, 2009 8:46 pm
My father and I a while back built a 91 ss for Rallyx and now i took up my own project last september.
Its a 94 legacy ss,
my symptoms are that my car cannot keep idle, and its losing power almost like a fuel cut off. i ran the test on it and its throwing codes for several sensors.
IAC (possible idle problem)
Knock (power losss)
Bypass Valve
MAF(power loss)
now when i changed the maf to a good one, it continued to tell me that my maf was no good.
i took off the iac and cleaned it and still continued to tell me these codes, now i know that this doesnt mean that my iac will work for sure...
i also tried changing the ecu, as well as i reset both of them and i got the same readings.
what do you guys think could be the problem?
maybe a chain reaction from one sensor?
Its a 94 legacy ss,
Knock (power losss)
Bypass Valve
MAF(power loss)
