I Need Some Tips Rebuilding a Stock Engine
Posted: Sun Feb 08, 2009 7:23 am
I'm doing my first rebuild as a school project (I'm in an auto tech program). I don't really have much money right now, but I really wanted to rebuild a Subaru motor, I just had to get my hands in one. I've got a million questions and I don't know where else to turn.
I need some advice on what to replace, and what I can get away with reusing. The engine is an EJ22EZ from a 1998 Legacy L (wagon, baby!), it had 204,000 miles on it. I do have a copy of the factory service manual.
I haven't measured it yet, but the class require's me to measure everything. I haven't taken the heads apart yet. I have taken the block apart completely. Unleash your wisdom, guys!
Engine Block Outside:
-When I took the timing belt tensioner off I (like an idiot) forgot to compress it, and just pulled the belt off. Will the tensioner be okay? Should I replace it? I haven't tested it yet.
-The water pump looks new, I don't think I need to worry about that.
-I haven't inspected the oil pump yet, but I think I'll just install new seals.
-I intend to get a an OEM gasket set, I don't want to push my luck with gaskets (~$230, link).
-Do head bolts have to be replaced?
Engine Inside:
-Like an idiot (not my doing this time!) the surfaces where the two black halves meet got scratched up from prying them apart. What is the best way of fixing this? Can I file it, or should I really have a machine shop take to it?
-Bearings weren't too worn (couldn't see any copper) but bearing #3 had a gouge in it from what appeared to be a defect on the crank (a small line of excess metal). Bearing #5 and the crank had smaller gouges where it seems some foreign matter came in through the oil gallery. I may have to get the crank machined, and if that's what I'm supposed to do, can I skip it (I know that'd be pushing it); or, if I get it machined, where can I get oversize bearings?
-Pistons and cylinders 1 and 3 had very good wear, nothing to worry about there.
-Pistons and cylinders 2 and 4 had lots of scuff marks on the top skirts and walls. Do they have to be replaced? What do pistons cost?
-What should I do about piston rings? Replace them, obviously, but are there any cool options? A friend said that some engines have aftermarket low friction rings you can get, is there a supplier for Subaru rings like that?
-Wear from piston rings looks good.
-Rod bearings look good.
-Carbon build up is minimal and even.
-EDIT: Holy crap, I was looking at www.subarugenuineparts.com, piston rings and bearings are going to run like $300?!? Aw man, can I go with aftermarket ones, are they okay?
Other:
-The clutch needs to be replaced, and there are clear signs of massive overheating on the pressure plate and flywheel. Is an overheated flywheel machinable? How important is getting the flywheel machined? I'd like to get an OEM clutch (~$280, link) for the quality, but are there cheaper clutches I can get that are almost as good?
-I intend to get an OEM tuneup kit (~$60, link) to minimize things I have to worry about it it doesn't run properly.
Random Notes:
-I've been doing a good job of keeping my parts in order.
-I have a running list of things to buy, I'll post it later so you guys can add to it.
-I have Subaru Bucks so getting OEM parts won't hurt my wallet so bad for the first $400.
Sorry for the bombardment with questions, my teacher is busy as hell and doesn't know anything about Subaru's specifically anyway. I've been through the stickies for engines, and searched NASIOC for tips too, but it's hard to find all the information I need in one place. Thanks guys.
Engine Inside:
Other:
Random Notes:
