F/S 542-615cc injectors Updated
ok Im sendig in a bunch of injectors for flow testing.
Now I have about 25-28 redtops that have been mod'd. Douglas V said they flow between 500-550cc's.
Once I get them all back I will match the best ones up with each other. Ill do my best to get the 2% between each cyl.
Now for asking price, Im not sure what to ask, Its going to cost about 22.00 each injector to have done and then shipping to you.
shipped to your door.
If your interested let me know now and I will put you done for a set to be yours.
Once I get comformation that they are over 480cc to 550cc then Ill update this post and start taking payments.
im slow---Location:Colorado
Got squirt? http://www.msextra.com/index.php
maybe interested since i wanted to do this anyway. how do i know which ones i need( like the cc's)
it all depends on your setup.
If you have a piggy back, if your using e85, if you have a wideband and know what you need
I figured it out for my setup, If I wanna use e85 I need 33% more fuel for a stock fuel setup, no piggy back. so 33% at 370cc equals 122.1cc more fuel required. So I need 492.1cc injectors to be stoich but im going with the biggest I can get out of this batch.
Im going to use a perfect power.
Im going with 520cc
Im going with 520cc
i have just stock engine, no turbo, no engine management. i want either stock injectors or maybe a little better than stock
You don't need anything other than stock. If you need to, just have your current injectors cleaned.
well i was going to have mine shipped out but since he is going to do it i thought maybe i would just by them so i wouldnt have to wait for mine to come back to me
can you sell me a set that has been cleaned that are stock for my car. my parents wont let me do any more work on the car since the neighbors keep turning us in to our community people. so i need ones that are ready done that i can just switch out and have the car running within a short period of time.
Ok a little behind due to it being a pain in the butt to mod that many.
Also forgot to mention they will get new Pintle caps on the end so it will hold the o-ring inplace with no problems
They are all being sent out tomorrow and I will hear from Witchhunter soon about them
ok results are back
Injectors range from 546cc to 615cc
as of right now I have 3 sets ready forsale
All injectors come with NEW o-rings and pintle caps (it holds the bottom oring inplace)
567cc
570cc
594cc
Now I also have some odd balls out of this batch. As you can see when modding these injectors it really can vary in the CC range. I plan on doing another batch with Witch hunter if he wants. He doesnt like to do the red tops so he kinda told me no but im going to see if he will one more time
Odd balls listed below
546cc
552cc
552cc
576cc
573cc
576cc
582cc
585cc
594cc
597cc
597cc
615cc
600cc
Now if you would like to buy a odd ball injector then its going to be 40.00 per injector.
Let me know what you want
Tyson
567cc
570cc
594cc
546cc
552cc
552cc
576cc
573cc
576cc
582cc
585cc
594cc
597cc
597cc
615cc
600cc
Tyson
