RHD Wagon Help
Posted: Tue Feb 17, 2009 7:44 am
I recently became the owner of a 1991 Legacy RHD wagon, and am having a little trouble with it.
After owning it for about three weeks, it started having problems idling when cold and not having much power, so I started checking, and one of the prior owners had removed the check engine light.
Anyway, long story short, the following parts have been replaced:
Knock Sensor (New OEM), Oxygen Sensor (New Bosch), Fuel Pressure Regulator (Old one was letting 45 PSI through, which probably fouled out the O2 sensor), New Plugs (NGK), New Fuel Filter, Used K&N off another Subaru of mine that died.
The MAF looks clean. The car starts easily enough, but if you give it any gas, it acts like it's going to die, and has almost no power. Putting it in drive results in the car creeping along, and almost dying. After the car gets warm, if you can get it up to about 1500 RPM, it starts running okay, not super-well, but okay.
This thing is making me nuts, and I'm looking for any ideas about what it could be.
And before anybody asks, No, I haven't check the TPS yet. I thought I would ask here before I started doing that. And the car is now running code free, but it's not running well..
Thanks in advance for any help.
