Rear Defrost/power mirrors
Posted: Fri Feb 20, 2009 6:33 pm
Ok. I bought my car 2 years ago and have never had rear defrost! I live in canada where there be winter!
So here is whats wrong with the rear defrost. The dash light lights right up no problem, but the glass never melts ice! The only place that can melt snow/ice kinda is the extreme outside of the windows and im not meaning the inside of the window i mean the outside of it! Aswell i tryed to remove the rear mini window plastic trim....You cant! its never impossiable! What do you need to do to remove the rear mini window trim plastic? Back seat? speaker covers? Im kinda at a loss here because you need to remove them trim panels to access the rear defrost cord that plugs into the window...
Aswell. My power mirrors/cig lighter have never worked. I put in a new fuse and it blows instantly! yes i know there is a dead short some where but i sure cant really see the problem. Its a rats nest up under the dash.
If you can make sense of it shot me a answer
Thanks!
Thanks!
