The little stainless steel brake pad spring holder on my Leg
Posted: Mon Feb 23, 2009 2:33 pm
by chayesfss
Fits between the caliper and the pads, what the heck is it for and is it needed?
I've been through so many sets of rotors, pads & calipers that I can't believe it. Now this time one of the pads was seized up in and couldn't move as a result of this thing, needless to say I'm about ready to through it out unless it's really of some use.
Posted: Mon Feb 23, 2009 3:14 pm
by tahiti350
that's an anti-rattle shim. probably not required for operation, but you may get more brake squeal...
Posted: Mon Feb 23, 2009 3:17 pm
by chayesfss
I figured as much but with the pad sooo tight on the fingers with that shim I think I'll pull it.
Posted: Mon Feb 23, 2009 7:22 pm
Just put some disc brake quieter on the back of the pad. The stuff from CRC works better then the stupid shims...
Posted: Mon Feb 23, 2009 7:59 pm
by chayesfss
No, I'm talking about the little pad finger shims not the pad backing shims
Posted: Tue Feb 24, 2009 4:46 am
by tahiti350
Oh, then my statement is void...
Posted: Tue Feb 24, 2009 5:44 am
by 93forestpearl
Do you use any synthetic brake caliper grease on namely the slides, but also those antirattle shims and the backs of the pads? If they are going really fast it sounds like they are dragging.
