Intermittent CEL on hybrid EJ25/EJ22T setup using EJ22T ECU
impreza_GC8
Post by impreza_GC8 »
Hello! Lately I've been getting a CEL that will come on within minutes of turning on the car and will usually only last 45 seconds to a minute. Sometimes it takes longer than a few minutes to turn on but it never lasts longer than a minute. I am using an EJ22T OBD1 ECU to run an EJ25 block with EJ22T crank/rods and a VF8. Is there a way to check what the code is after the light turns off?
-'97 Outback - EJ25 block/pistons/HLA heads, EJ22T crank/rods/ECU, EJ20G intake manifold/fuel rails/440cc injectors, VF8 @ 11psi. . . . Fuel cut > me
impreza_GC8
I plugged in the gray and black connectors, then turned my car to the on setting and all I heard were the fans cycling and this strange clicking sound coming from the engine compartment. The CEL just stayed on the whole time. This is not what is supposed to happen according to the instructions.
magicmike
Post by magicmike »
Should be two black connectors if i'm not mistaken. right side under dash.
2007 Ducati 800ss - Current
2003 Infiniri G35
1998 Infiniti I30t
1995 Honda Civic DX
1987 Subaru GL Wagon
1987 Subaru Loyale
RJ93SS
Post by RJ93SS »
You did it wrong.
black to black, green to green, play with gas pedal, start the car read it over.
if you just want stored codes, only hook up black to black and turn the ignition on, not the motor, the codes will flash
impreza_GC8
Hm. I never saw a black to black option. Only black to gray and green to green. But my wiring harness has been merged with an EJ25 harness and the plugs were relocated to the passenger floorboard near the ECU. Its possible there is another set of plugs hiding under the dash where they should be. I'll give it another go.
This is what the connectors should look like.
http://www.main.experiencetherave.com/s ... cuhide.jpg
impreza_GC8
^ Yeah, green-green & black-gray. Mine aren't under the dash due to the ECU rewire. I'll take a pic of mine and see what you guys have to say. From my memory, it looked like one of the wires was cut. I didn't do the wiring, so I'm really not sure. Thanks for being helpful, I'll get a pic up when I get back to my car this weekend.
n2x4
Post by n2x4 »
All you're really doing when you connect that black plug is grounding it out to the ECU, which triggers the codes to flash. If you don't have the other end of the plug, then I'd ground it out to somewhere else on the car.
If you look at the FSM the lead from the ECU for the trouble code output (black wire) just goes to a ground.
SUBARUEHS Racing
