Running a 2.5L on a 2.2L ecu... Will I have problems??
Posted: Tue Mar 03, 2009 10:47 pm
by smh0101
I'm working on my engine build... And I'm going with a 2.5L shortblock and 20g WRX heads.
My question... Will I be safe running it on the stock 2.2L ecu without anything extra? Or will the extra displacement cause problems?
thanks!
Posted: Tue Mar 03, 2009 11:03 pm
by PhyrraM
The larger bore might need more timing to be optimal, but I'm sure it will run fine if you keep the boost reasonable.
Keep some sort of engine management on the short list though.
Posted: Tue Mar 03, 2009 11:09 pm
by smh0101
It wont run too lean because of sucking in more air?
Posted: Wed Mar 04, 2009 12:08 am
by PhyrraM
smh0101 wrote:It wont run too lean because of sucking in more air?
The AFM will take care of that, until it maxes out. Keep your boost under that limit and A/F ratio should be OK. Of course with that displacment change, that limit might only be a few PSI.
Posted: Wed Mar 04, 2009 3:30 am
by 555BCTurbo
Keep in mind the manifold absolute pressure will not change...so I wouldn't worry too much...
Posted: Wed Mar 04, 2009 3:38 am
by impreza_GC8
I am running a hybrid EJ25 turbo setup with an EJ22T ECU.
Posted: Wed Mar 04, 2009 4:22 am
by smh0101
Thanks guys! Definitly some good info here.
And yea, EM is next on the list once the engine is built.
impreza_GC8 wrote:I am running a hybrid EJ25 turbo setup with an EJ22T ECU.
And I take it all is well?
Posted: Wed Mar 04, 2009 6:59 pm
Check out this thread
http://bbs.legacycentral.org/viewtopic.php?t=15368
Jason Grahn did this a while back, and I don't think he had any issues.
Posted: Thu Mar 12, 2009 4:36 am
by impreza_GC8
Runs like a top. It loves its gas though. 440 injectors, a VF8 and no ability to tune can be blamed for that though.
Posted: Thu Mar 12, 2009 1:18 pm
by tahiti350
wouldn't the ECU be off due to the RPM and MAF conflict (IE, more air flow at all RPM's) or does it have enough latatude to adapt?
Posted: Fri Mar 13, 2009 4:33 am
by douglas vincent
I have advised Spencer I will refuse to sell him a 2.5 unless he buys a PP6 first.....
Posted: Fri Mar 13, 2009 4:35 am
by smh0101
And I will do so :D
I'm working on it!!
Posted: Fri Mar 13, 2009 5:37 am
by impreza_GC8
tahiti350 wrote:wouldn't the ECU be off due to the RPM and MAF conflict (IE, more air flow at all RPM's) or does it have enough latatude to adapt?
Like I said, it runs pretty well. I didn't do the engine build though. Its possible it is running the EJ22T RPM sensors and junk but if you think about it, it just takes the data from the sensors and makes an equivalent combustible air/fuel mixture from that data. Doesn't really matter if you flow more air or not.
