Major brake light issue
Posted: Wed Mar 04, 2009 3:31 am
Major as in I can't get them work! I'm working on my project build, which is an RS-RA body and using GT components to finish get it working. Okay, so the entire front harnesses are from the GT, and the rear harness is the original RS-RA. They are both of the same MY (only 5-6 build months apart). I'm totally confused since everything should be P&P and just work, but it doesn't. I've ruled out the switch at the brake pedal too. The rear lights do work when I turn on either the park or headlights, but when I stamp on the brake pedal I get nothing. Where does that leave me? I can't find any relay, and I've checked every fuse I can find and all are functional.
To make matters more confusing I'm using a service manual for the Aussie spec on a JDM sedan using JDM wagon parts.
Indicators are also a go (for a day), but I haven't sorted out the reverse lights since they aren't vital.
Also can the hazard/indicator control unit be fixed? Mine recently started to make a weird buzzing sound and I've got no indicators as well.
