F.S. (Another) jecs maf, turbo ecu, coolant tank, bpv.
Posted: Wed Mar 18, 2009 9:12 pm
by klin7757
need to get the garage cleaned out, so i have a few things for sale.
jecs maf. SOLD
turbo ecu $65 shipped (mt)
stock coolant tank $45 shipped
stock bpv $25 shipped...Pending...
Posted: Thu Mar 19, 2009 12:17 am
by joeWM
will the jecs maf hook right up to our cars?
Posted: Thu Mar 19, 2009 12:26 am
by PhyrraM
joeWM wrote:will the jecs maf hook right up to our cars?
It will plug right in and bolt up no problem. You should use some form of management though. It will throw a code and run lean on a factory ECU. But with proper supporting mods, the JECS can measure more air than the Hitachi.
I have an *untested theory* that a JECS and JDM 440cc injectors on a factory ECU would make a good match. But test on your own risk. :wink:
Posted: Thu Mar 19, 2009 4:57 am
by klin7757
^ i concur. i've wanted to try the maf and injector conbination for a while now, but haven't had the time. i've read somewhere that if you ground the blue wire on the maf connector it will get rid of the check engine light. don't quote me, but might be worth a try. btw though the maf is pending sale. might be able to find another if you're interested.
Posted: Thu Mar 19, 2009 5:02 am
by SILINC3R
if i want to use a turbo radiator on a N/A could i use the coolant tank so i could use the turbo rad. since i know the turbo rad dont have the filler caps and the N/As do
Posted: Thu Mar 19, 2009 5:19 am
by klin7757
you would need a coolant expansion tank with a turbo radiator, but unless you plan on running a turbo i think a turbo radiator may be overkill. the extra cooling capacity of a turbo rad. probably just isn't needed. although if you have your heart set i could still sell. :wink:
Posted: Thu Mar 19, 2009 5:28 am
by joeWM
oh, well shit i dont money to spend on injectors to, i dont think i want to get that deep yet either
Posted: Thu Mar 19, 2009 6:25 am
by SILINC3R
klin7757 wrote:you would need a coolant expansion tank with a turbo radiator, but unless you plan on running a turbo i think a turbo radiator may be overkill. the extra cooling capacity of a turbo rad. probably just isn't needed. although if you have your heart set i could still sell. :wink:
well isnt that the stock coolant tanks the coolant exspansion tank or is that something else
Posted: Thu Mar 19, 2009 6:41 am
by klin7757
same thing, longer name.
Posted: Thu Mar 19, 2009 7:31 am
by SILINC3R
ok thanks :D
coolant tank
Posted: Sun Mar 22, 2009 1:55 pm
by jaybirde508
Is the tank still avalable ?
Shipp to 01440 how do I pay
Posted: Sun Mar 22, 2009 7:48 pm
by klin7757
indeed it is. pm'd.
Posted: Sun Mar 29, 2009 8:50 pm
by scootledoo
intresed in stock coolant tank, how much shipped to 99205? pm me please
Posted: Mon Mar 30, 2009 7:46 pm
by Airgne
whats the part number on a jecs so i know im getting the right one before i buy it?
Posted: Mon Mar 30, 2009 8:02 pm
by klin7757
it is part #22680 AA160.
Posted: Tue Apr 07, 2009 11:14 pm
by klin7757
Got another Jecs. 45 + shipping.
Posted: Wed Apr 08, 2009 2:58 am
by Airgne
ooooo. i want the maf!!!
Posted: Wed Apr 08, 2009 6:35 am
by adema2626
I'm also interested in the MAF as well. Let me know how much shipped to 97333.
Posted: Wed Apr 08, 2009 7:32 pm
by diego0decastro
If you still got the MAF and the BPV i'm interseted and i'm down in boulder, CO
Posted: Thu Apr 09, 2009 2:57 am
by Airgne
money sent for the MAF.
Posted: Wed Apr 15, 2009 5:11 pm
by AutoLegacy
Please PM me if coolant tank is still available. I will send money today.
Posted: Wed Apr 15, 2009 9:26 pm
by AutoLegacy
Money sent for the Coolant Tank. Thanks
