1991 EJ22T vs. '92-94 EJ22T- Engine only
wtdash
Post by wtdash »
I've searched, but I've only found that the '91 has the oil cooler (w/a different water pump).
From my collection of '91 EJ22T parts I bought from dwreck30 I've seen:
- Different IM harness plugs = matches the '90-91 NA plugs by the battery.
- Idle adjustment screw on the TB.
What else is different?
I'm putting the '91 back together and wondering if it's got any advantages over the '93 I swapped in. 160K on the '91; 140K on the '93.
Turbo Subies:
'87 GL-10 Turbo - SOLD
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
PhyrraM
Post by PhyrraM »
You just about covered it. Those are the only things I have discovered also. For all reasonable purposes they are identicle.
