Turbo -> NA flywheel compatibility?
who1981
Post by who1981 »
I guess my question boils down to:
Will a non-turbo (push type) clutch and pressure plate fit on, and work properly with a flywheel from a turbo (pull type) vehicle?
I have a '90 NA 5MT Leg (with a very bad clutch), I can get a WRX ACT Streetlight flywheel cheep (less than a resurface)! Will this work?
Are Turbo and NA flywheels even different? Other than perhaps the Turbo fwheel having a 5mm larger friction surface?
Thanks,
Stephen
Matt Monson
Post by Matt Monson »
Nope. Won't work. They are different. Different disc size and bolt pattern.
2000 2.5RS daily driver.
1999 2.5RS w/ 50+ extra whp
Suby Hai!
who1981
Post by who1981 »
Thanks,
First real answer I've found.
Cheers,
Stephen
