wtb crankshaft
Posted: Sat Apr 04, 2009 9:02 pm
by the_watts10
looking for a 2.2 NA crankshaft or any subaru crankshaft that will be a direct fit!!!
Posted: Sat Apr 04, 2009 9:38 pm
by PhyrraM
To help increase your chances, also look for a EJ18 or EJ22T crank. It's the same parts.
An early EJ20G crank would also be the same, but those are JDM so not as common.
I've got one if you get desperate, but prefer to hold onto it unless you really can't source one local/closer.
Posted: Sat Apr 04, 2009 10:17 pm
by the_watts10
my uncle is a subaru technician and i have talked to him i have my ej22t crankshaft as well as a ej18 crankshaft but how would a 2.5 dohc na block and 2.2 heads work out would that increase horespower and if im correct the ecu wont know the difference right?
Posted: Sun Apr 05, 2009 12:10 am
by Blackbart
I have several ej22t cranks in good shape, $60 each shipped.
Posted: Sun Apr 05, 2009 12:49 am
by asc_up
^ HE'S BACK!
Posted: Sun Apr 05, 2009 3:18 pm
by green91
Ive got a ej22t crank also, #2 rod journal needs polish but ill sell for cheap!
Crankshift
Posted: Tue Apr 07, 2009 8:10 pm
by jaybirde508
Ive got a ej22t crank also, #2 rod journal needs polish but ill sell for cheap! Also ...no joke on craig's in worcester,ma
