Sti Pink Injectors
Posted: Mon Apr 06, 2009 7:34 am
heya,
i just bought some v7 sti pink injectors 550cc to upgrade from my 440cc to be safe
the engine they are going on is a ej20g with ej20r heads
now the pinks are top feed and the yellows are side
how do i install the pinks so they work like they would factory
also i am doin a split rail at the same time i have 2x v5sti regs
and 2x matching ej20g fuel rails also have 2x ej20h as well and also i have an ej20h intake manifold and also an ej20g manifold
can anybody tell me what i would need to make the injectors ft and work i heard that you could use standard N/A rails that have the red injectors ??? but then i relised that the pinks are top feed
Cheers any help would be greatly received
