Machine shop recommendations in Washington...
Posted: Mon Apr 20, 2009 12:11 am
by logan9691
Don't know where to post this, but I'm looking for some machine shop recommendation in Washington, preferable NW area.
Thanks in advance...
Posted: Tue Apr 21, 2009 5:16 am
by AWD_addict
I've used Reed Machine in Bham for simple stuff. They are quick and have done fine work.
Action Machine near Seattle has done some quality work (engine internals), but seem to be more expensive.
Do what you can by yourself before bringing your parts in, that can save some labor costs.
Posted: Tue Apr 21, 2009 5:26 am
by logan9691
alright cool
what can be done to the heads? (i was thinking valve job, cams, port and polish) is there anything else can be done?
and thanx for moving this to the right spot...
Posted: Tue Apr 21, 2009 5:36 am
by AWD_addict
I'm not sure if you'd want to take the heads apart beforehand or not. If the shop isn't really familiar with Subaru heads you should probably bring them in assembled, rather than a box of loose parts. That way they could rebuild them more easily since that seems to be what you're looking for.
I would make some calls and talk to various shops, find out who you like.
I didn't move this, I'm not a mod.
Posted: Tue Apr 21, 2009 6:12 am
by douglas vincent
Delta Camshaft rebuilds heads....
Posted: Wed Apr 22, 2009 1:39 am
by logan9691
thats who i am looking at for cams, but they're being a lil slow in returning my email for info on stuff, from what little i have read their prices are fairly responsible to.
Posted: Wed Apr 22, 2009 5:56 am
by beatersubi
douglas vincent wrote:Delta Camshaft rebuilds heads....
Custom Import Heads rebuilds heads, Delta Camshaft grinds cams. Same company, though. You'd probably get faster results if you called.
