What is the stock rev limiter for an EJ22T ECU?
impreza_GC8
Post by impreza_GC8 »
I am running my hybrid EJ25 setup in my Outback off an EJ22T ECU. I was wondering what the rev limit is because I feel like a rev limiter kicks in before the redline on my tach (1997 Outback gauge cluster).
An idea came to me today that my valvesprings could be worn out causing them to float at ~5800-6000 rpm and not letting me get to the full 6500. I have 1996 HLA heads, do they even allow valvespring float?
Thanks for the info. I searched on the rev limit and came up with a result but I still want to know what you guys think.
-'97 Outback - EJ25 block/pistons/HLA heads, EJ22T crank/rods/ECU, EJ20G intake manifold/fuel rails/440cc injectors, VF8 @ 11psi. . . . Fuel cut > me
I didn't know there was a rev limiter. But I've only really got experience with the 4EAT with the EJ22E motor. So I just assumed the rev limiting was going on because of the automatic transmission. When I had that car and you put your foot to the floor and held it there it would shift every gear right at the redline which was either 6K or 6500, it's been a while. That was a 90 with a 94 tranny. The crappy stock tranny died 2 weeks after I had it and before it died it would NOT shift unless you let off the gas a bit. So no rev limiter haha!
I had a 5speed for a while but I only drove it about 5 times and I never pushed it because I didn't want to snap the timing belt like I did in the 90. Then I sold it.
impreza_GC8
Ok. Well there is a rev limiter. Anybody else have any input?
kleinkid
Post by kleinkid »
Would fuel cut out occur before a rev limiter function on an ej22t ecu?
n2x4
Post by n2x4 »
My ej22t sees redline at 6500 dead on. Maybe your tach is off? I suggest hooking up the scantool to see what RPM signal your ECU is reading.
SUBARUEHS Racing
wtdash
Post by wtdash »
kleinkid wrote:Would fuel cut out occur before a rev limiter function on an ej22t ecu?
Only if your running more than 13 psi. At stock boost ~9 psi, rev limiter should step in 1st.
Fuel cut is very abrupt, too.
I'm not hit the rev limiter as the the 4eat always shifts before I get there @ about 6200 rpm....and run out of road or cojonas in 4th. :)
Turbo Subies:
'87 GL-10 Turbo - SOLD
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
Matt Monson
Post by Matt Monson »
The rev limiter is 6500 on the Ej22T ECU.
As was mentioned it would hit fuel cut at lower rpms if the boost is too high.
It's definitely not the heads or valve float. Redline on the DOHC Ej25d powered cars is also 6500rpms.
2000 2.5RS daily driver.
1999 2.5RS w/ 50+ extra whp
Suby Hai!
impreza_GC8
Matt Monson wrote:The rev limiter is 6500 on the Ej22T ECU.
I agree with the redline being ~6500 on other EJ25 cars. My 2.5RS is that way I think. I hit fuel cut in 5th because I am running an MBC at 11psi and the increased load of 5th gear causes the turbo to hit 12psi which is where fuel cut lies. Its possible my tach is off, I am running smaller diameter tires but I figured that wouldn't have a bearing on the reading of the tach, only the speedo and odo. My engine just revs very odd when compared to my N/A car. At redline the rpms will just "lope" off the limiter whereas my N/A 2.5RS will literally "bounce" or zing off the limiter. It is a very different feeling for both cars. Thanks for the replies guys.
Matt Monson
Just for the record, your RS has a 6250rpm fuel cut.
Suby Hai!
impreza_GC8
^ You are correct, I couldn't remember what it was exactly but I knew it was something with 50 at the end. Thanks!
