EJ20H Twin Turbo Engine UPDATE: Engine is taken apart now
Posted: Wed May 13, 2009 2:30 am
*NOTE* This is an EJ20H motor, not K, that was an accident and I changed the title. I was told this motor from was from a 95 legacy but that is not a guarantee because it was bought from a guy locally and not the importer.
I finally got an EJ22T engine for my car and I'm pretty broke so I've decided in order to buy gaskets, timing belt and hoses for my engine I'll need to sell the twin turbo engine. I don't think I'll have a use for it in the future anyways.
I was originally going to use this engine in my car until I did a leak down test on it and one of the cylinders has a 75% exhaust valve leak. The other cylinders are fine and there seemed to be minimal leakage coming from the intake valves. I was told to just put it in the car anyways and see how it does and I was going to do this but I moved out of my parents house and don't have much time to work on it.
The motor is in pretty good shape. It has a brand new oil pump, water pump, knock sensor, timing belt, idlers, thermostat and intake gaskets(not installed). These were all bought from 1stsubaruparts.com except for the timing belt and idlers and I have the receipts to prove it. The motor can come with these parts but I'll have to charge full price for them because I need them for my engine and if you want them with the motor I will have to buy them again at full price. If you don't want them, I can remove them from the engine and put the old parts back on. The timing belt and idlers I have no use for so those come with the engine. I got them off ebay. You will still save on shipping if you want the parts though and you won't have to install them! They've all been torqued to facotry specs via the Factory Service Manual.
Also has brand new cam seals and crank seal.
Comes with both turbos VF13 and VF14. I think it has both up pipes but I only saw one when I was taking these pictures, I'll have to look for the other one. It comes with the twin turbo exhaust manifold. The VF14 spins freely with no shaft play. The VF13 has no shaft play but doesn't spin freely. It will spin by hand but it has some resistance.
I'm not shipping this, you'll need to come pick it up.
Any questions, don't hesitate to ask.
-Kimo
Knock Sensor $59.58 - 22060AA030
Thermostat $11.48 - 21200AA071
Thermostat Gasket $2.47 - 21236AA000
Water Pump $86.36 - 21111AA021
Water Pump Gasket $2.86 - 21114AA030
Oil Pump $115.16 - 15010AA103
Total - $277.91
$300 (was $350) for the motor
$575 (was $630) motor with new parts
-Kimo
Total - $277.91
