sunroof motor?
Posted: Thu May 14, 2009 4:02 am
by Mattheww044
hey guys im not quite sure if its the motor or what, but my sunroof is stuck open (up), when i push the button i can hear a click but it doesnt budge. it used to work SOMETIMES, now it just doesnt work at all, should i see if i can snag a motor for cheap or do you guys thing its something else?
Posted: Thu May 14, 2009 4:04 am
by ericem
I would bet on the switch more than the motor. I believe there is a crank in the center console and you can close the roof with it from somewhere. Not sure where though lol. I can not find this on my car actually and was curious.
Did you try pushing the button really hard, or multiple times to see if it budges? I am sure there is a relay somewhere too.
Posted: Thu May 14, 2009 4:11 am
by Mattheww044
ya i tried pushing it several times, and i pushed it pretty damn hard, ill see if i can get some switches from someone thanks eric
Posted: Thu May 14, 2009 4:16 am
by ericem
You know what mat maybe hit the back area shown in this diagram where the motor and control unit is. If it works, it is probably something back there.
http://www.main.experiencetherave.com/s ... blowup.jpg
Posted: Thu May 14, 2009 4:59 am
by Mattheww044
ok i will give that a try for sure.
thanks man!
Posted: Thu May 14, 2009 5:15 pm
by SILINC3R
the manual crank hole is in the back seats looking up. you cant miss it
Posted: Fri Feb 26, 2010 3:55 am
by SiCkSTi04
hey Matthew were you ever able to fix this problem? i think mine is on its way with the same symptoms.
Posted: Fri Feb 26, 2010 4:04 am
by SubiePrice88
DUDE Matt...I had this car once remember? You gatta hit where the buttons are with your fist..that always worked for me HAHA
Or use the crank hole in the back
other than that there is a problem somewhere, I just never worried about it cause it doesnt leak
****EDIT* nevermind, didnt realize the dates on this thread. I thought it was about matts current car *EDIT****
Posted: Fri Feb 26, 2010 5:02 am
by ericem
Probably just the switches then lol. Old thread bumped up
Posted: Fri Feb 26, 2010 5:54 am
by Mattheww044
yea, this was about the Radio Flyer, worked perfectly when I bought it, and about a week later it went to crap, I replaced the switches and no luck. It seemed to work on and off. My new car works "most" of the time! And no swimming pools in the drivers seat!!
Posted: Fri Feb 26, 2010 6:09 am
by kimokalihi
Manual crank is directly above and center of the back seats but you can easily miss it actually. It's covered by a plastic plug in the headliner. I would never have thought to look there.
Try cranking it. It it's hard to crank or won't crank at all, maybe the cables have dried up and siezed. That's how my sunroof was.
Posted: Sat Feb 27, 2010 9:31 am
by SiCkSTi04
i used the method of slap the back end of the head liner and sure enough it worked lol any reason why tho?
Posted: Mon Mar 01, 2010 4:29 am
by __TT__
I've actually fixed this issue a few times already on mine and my sisters. It's faulty micro switches that tell the controler what position the sunroof is at. they are little and black near the motor on the drivers side. There are three two of them are together and one is by itself.
they should be replaced or I just took them out and soaked them in electrical cleaner works well
Posted: Mon Mar 01, 2010 5:19 am
by SiCkSTi04
Hey _TT_ where did you buy the micro switches from? thanks!@
Posted: Mon Mar 01, 2010 7:55 am
by __TT__
never found them hence the cleaning
Posted: Mon Mar 01, 2010 8:35 am
by SiCkSTi04
ahh! forgot the "I" sorry
