WTB: FWD Axle
Posted: Mon May 18, 2009 7:48 am
by strawman
I am looking for a front wheel drive (two wheel drive) axle -- one of the big ones. I don't care if the boots are torn -- this is for an experiment, so it doesn't have to be pristine. If it is located in/near Sacramento, that would be even better. The axle shaft needs to be 1.13" in diameter measured mid-way between the CV joints. What ya got and how much shipped to 95618?
Geoff
Posted: Mon May 18, 2009 2:38 pm
by beater_legacy
I've got one for ya. I'll check the diameter later when I get home. Its in good shape.
Shipping will be a bit much to CA though. How about $50 shipped?
Posted: Mon May 18, 2009 4:41 pm
by strawman
Yeah, as long as the outside diameter of the axle shaft is correct (I've edited my original post -- the diameter should be 1.13" measured mid-way between the CV joints). PM me with the results of your measurement check and provide your Paypal address.
Geoff
Posted: Tue May 19, 2009 1:43 am
by beater_legacy
The battery in my digital calipers is dead and the manual measurements aren't that precise, but it looks to be just a hair over an inch in diameter. It's just a standard FWD Legacy axle, most likely not stock. Let me know if you're still interested and I can pull it and have it right out to you.
