Valve tick - not HLAs....
Posted: Thu May 28, 2009 2:24 am
Hi Fellas... Long story short, I put a new NA motor in my wagon ~2 years ago (only had 7k on it). At the time I did not remove all the rubber seals/etc. from the new motor and lube them as I should, so I expected a few leaks (which happened) and maybe some beat up lifters (which I replaced).
I'm now turning about 40k on the motor and getting what sounds like a valve tick on the D-side head, only when the motor is warmed up. The tick is not present when the car is first started, and only make's itself known when the motor gets up to temp, at which point it is persistent. I initially thought maybe it was a bad lifter, so I bled and replaced them - but the noise has not changed. It's been getting progressively more pronounced in the last month or so; before it was only audible in the driver's seat, but now I can hear it when I put my ear to tailpipe with the car idling. At the tailpipe it makes a distinct "tink-tink-tink..." noise roughly once every 4 revolutions or so (roughly 3-4/second at ~600 rpm idle). The noise changes with RPM, and goes away (or is washed out) above 1600 RPM or so. I haven't seen a loss of power or an increase in oil (or fuel) consumption or blowby.
I'm beginning to think it's a sticky exhaust valve guide that perhaps expands when the engine is warm and is retarding the valve ever so slightly on closure, any thoughts?? My idle is also slightly rougher than I think it aught to be. I don't have a whole lot of experience with top end, so I'm at a loss. Thanks for the help!
