Ballbearing sound
Posted: Mon Jun 08, 2009 7:12 am
by Airgne
ok so i put oil in the stock used vf11 i got (didnt know how long it was dry)and got the ball bearing sound when i started it up. now after about 20 min its gone. is there a screen in the 1st gens oil feed line? ive heard of these getting cloged and burning up turbos. any help would be very nice.
Posted: Mon Jun 08, 2009 5:06 pm
by asc_up
I don't believe there's screen, at least I've never seen one.
Posted: Mon Jun 08, 2009 6:26 pm
No, there's no screens.
Posted: Mon Jun 08, 2009 6:57 pm
by Airgne
ok. thank you.
Posted: Thu Jun 11, 2009 8:52 pm
by A1Fiddler
That's cool you got it in. I hope it works out for you. Get that SS back on the road!
Posted: Thu Jun 11, 2009 11:14 pm
by Airgne
the banjo bolt broke. have to get a new line as well.
Posted: Fri Jun 12, 2009 3:32 am
by A1Fiddler
That sucks, though I don't even know what a banjo bolt is.
Posted: Fri Jun 12, 2009 3:56 am
by Airgne
its a bolt that goes into the block and the turbo. they are hallow. they supply your turbo with oil.
Posted: Fri Jun 12, 2009 4:55 am
by Skruyd
A1Fiddler wrote:That sucks, though I don't even know what a banjo bolt is.
A banjo bolt is a bolt with a hole in the center and on it sides. They are commonly used on brake calipers to connect the brake line to the caliper, and any other application that needs fluid to pass through a bolt
Here is an example. Disregard the hole drilled on the head, it's for a safety wire.
Posted: Fri Jun 12, 2009 5:01 am
by Airgne
Skruyd wrote: Disregard the hole drilled on the head, it's for a safety wire.
wow someone know what saftey wire is.
Posted: Fri Jun 12, 2009 3:48 pm
by Skruyd
Airgne wrote:Skruyd wrote: Disregard the hole drilled on the head, it's for a safety wire.
? Do people give you the "wtf are you talking about" look when you say safety wire or something?
Posted: Fri Jun 12, 2009 3:53 pm
by Airgne
Skruyd wrote:Airgne wrote:Skruyd wrote: Disregard the hole drilled on the head, it's for a safety wire.
none military aviation ppl.
Posted: Fri Jun 12, 2009 5:07 pm
The safety wire is common on gas turbines. We see them on almost all the stationary gas turbines that are used for the gas compressors for the pipeline.
Posted: Fri Jun 12, 2009 10:25 pm
by Skruyd
ahh ok. Some of the old military vehicles had it too. Mostly for the hubs.
