E-Brake Light
Posted: Wed Jun 10, 2009 1:39 am
by SubaruNation
it wont go away.
any suggestions?
the E brake needs tightening, and that might be why..
any other ideas would be great too
thanks,
Posted: Wed Jun 10, 2009 3:32 am
You're not low on brake fluid, are you?
Posted: Wed Jun 10, 2009 3:36 am
by SubaruNation
It was then I filled it. Floater maybe stuck?
Posted: Wed Jun 10, 2009 3:51 am
Yeah, I'd check that. Check the rubber gasket in the cap -- it extends down into the reservoir as the fluid level drops, and you're supposed to push it back up when you add fluid or replace worn pads. It may be pushing the floater down.
A loose parking brake cable won't trip the light.
Posted: Mon Jun 29, 2009 11:31 pm
by SubaruNation
fixed it thanx vrg3 :-D
