SS brake line help?
Posted: Thu Jun 18, 2009 7:52 pm
by SPUMONI_RT
I am looking for some SS braided brake lines and i was wondering if these will work.
http://www.jegs.com/p/Russell/Russell-B ... 3/11059/-1
Posted: Fri Jun 19, 2009 12:08 am
by asc_up
I know they'll connect on the brake side of the line, just not sure if the other side will connect to the main system. I would assume it would.
Posted: Fri Jun 19, 2009 12:17 am
by PhyrraM
They will fit the ends just fine. The brackets to mount them to the struts are slightly different. Most of us use wire ties without any problems.
Posted: Fri Jun 19, 2009 8:04 pm
by SPUMONI_RT
Thanks for the help
Posted: Sat Jun 20, 2009 2:56 pm
by magicmike
I got these and they are really nice. With these you can slide the section that clips to the body around to match the factory line. The ones you linked to don't have this and they cost the same money.
http://www.tirerack.com/brakes/brakes.j ... perfCode=S
FYI I noticed ZERO pedal feel difference after upgrading these. So if your changing out for that reason i'd think twice.
Posted: Sat Jun 20, 2009 3:00 pm
by kimokalihi
magicmike wrote: FYI I noticed ZERO pedal feel difference after upgrading these. So if your changing out for that reason i'd think twice.
That doesn't surprise me. :D
Posted: Sun Jun 21, 2009 10:35 pm
by SPUMONI_RT
Well that was the reason so i'm going to buy a new muffler instead
