air bag
Posted: Fri Jun 19, 2009 7:59 am
by uberoo
Im short and oddly proportioned.My legs are shorter and my torso/arms. So to get full pressure on the pedals I have to sit really close to the airbag.Can I disable the air bag by simply pulling the fuse or would it ignite at a bad time?Or do I have to unplug the airbag computer as well?Thanks.
Posted: Fri Jun 19, 2009 11:00 am
by BSOD2600
If you don't mind the airbag light always on, just unplug the airbag... follow the bright yellow wires/connectors.
Posted: Fri Jun 19, 2009 6:32 pm
by uberoo
So how can I disable the airbag without the light being on all the time,And no possible way it would ignite?
Posted: Fri Jun 19, 2009 6:39 pm
by PhyrraM
uberoo wrote:So how can I disable the airbag without the light being on all the time,.......
You can't. The only way to keep the light off is to pull the actual bulb. Check out my build thread (see sig) for how I did it.
To disable the bag, you need to get some security torx bits (with the hole in the middle) to remove the airbag, then you can just pull the plug on it. If you pull the one plug under the column, you will lose the horn and cruise control also. You could pull the plugs from the controller under the console too.
If your really worried about it, you can even pull the charge canister from the assembly after that.
Posted: Fri Jun 19, 2009 7:06 pm
by uberoo
The controller is under the center counsil(ie where the handbrake is)? If so I will unplug it when I put in my new shoulder belt.
Posted: Fri Jun 19, 2009 7:18 pm
by PhyrraM
The controller is under the console under the radio. Notice how the center console rises as it moves forward of the shifter? That's clearance for the controller. Again I refer to my build thread, look for the pics of my WRX shifter install.
The plugs on the airbag controller are very difficult to work with. Be warned they might even need special tools to disengage them.
Posted: Tue Jun 23, 2009 7:55 pm
Duct tape can also be used to block the bulb discreetly:
http://bbs.legacycentral.org/viewtopic.php?p=294280
Posted: Sun Aug 16, 2009 7:19 pm
by yazmo
i gt the same problem its been two 2 i have notice this my abs light stay on sometime if i turn off engine and turn it back on light go off anyone know what is the problem?
i have check the fuse eveything look fine
i play with the radio those last 2 day
anyone as a clue?
each time i fix something there is something else geez anyway is that dangerous i dont mnd is the light stay open really, may be a problem if i decide to sell the car.
