wire mating 22T harness & 25D equipment
Posted: Thu Jul 02, 2009 9:52 pm
ok here i have a 22t harness & ecu with a 25d engine together
- i ve kept the sst engine harness near OEM as possible , concidering a few clip alterations and wire extentions
1st up ? are the crank angle and cam angle sensors between the years concidered the same-as in signal to the ECU- or different?
-i m looking to keep the 2.5 sensors & cut\paste in the 22T wire harness
-the wires are white and black off the sensors and different colors on the harness : - to cut & paste , how is there a way to determine which of the wires is pos+ or neg- ?
-is this possible to do this with a multimeter ?
i have Manny Legacy questions
