Clutch cylinder issues post-install
Posted: Fri Jul 03, 2009 7:25 am
Finally got the engine back into the SS tonight. First thing I started to mess with was the clutch fork (aka release lever) and cylinder.
Right away, I noticed the release lever would move back and forth really easily -- where as before it was basically unmovable. I started to doubt if I installed the release bearing in the correct direction onto the shaft. Did some reading in the FSM and noticed that I need to push the release lever into the clutch cover. Went out and tried that and it seemed to work. Now the release lever is solid and doesn't want to move. Think I'm safe there.
Next is the blasted clutch cylinder and bleeding. During the removal of the engine, etc I had pushed in the pin on the end of operating cylinder. I noticed some fluid came out the bottom of the rubber that holds the pin. Now with the engine installed, I tried to bleed the dampener. Had a friend sit in the car, press the foot down on the clutch, while I loosen the bleed screw, watch fluid shoot out and then tighten it. Pump the pedal some more and repeat.
During the course of all this bleeding, the cluch pedal travels about half way to the floor very easily. THEN it gets almost rock hard, with very little travel -- sort of feels likes a brake pedal. Through all the bleeding I did, this never changed. WTF?! On my TW, I never had this dampener crap, so not sure what the deal is. Suggestions?
