So I think I must have gotten really confused on the suspension sticky?
On my 91 SS I tryed to use 06 wrx springs (whole set) but the front
springs on the wrx have an 6inch od at the top, as to my stock springs are a 7inch od. so what top hats or perches to I have to use to use the wrx springs? GC/GDA?
While I'm at it what would these springs do besides having a higher spring rate. raise/lower?
I purchased a set of gabriel struts, and I've been told that the struts for a 94 SS will work?(agx)different front strut lengths? Thanks
Suspension confusion!!!! HELP
91legacyawdturbo
2002 wrx sport wagon
read this?
http://bbs.legacycentral.org/viewtopic.php?t=22419
aside from that, according to the sticky those springs are only gonna net you 30# over the stock springs. 130# vs 160#. Thats about mmmm.... 20% stiffer. FYI
FWIW, I think the spring ID is the important bit. Still haven't swapped springs on mine so wathing for good info!
'92 Legacy SS, AGX, GC coilover, ALK, 20mm ARSB, FCD, MBC, iceracer, rallyx and DD
'87 Mustang GT roadracer, to many mods to list
