How do you know which connector goes to which injector?
Posted: Sat Aug 29, 2009 4:11 pm
by kimokalihi
I just put an EJ22T harness on my EJ20G and I don't know which connector goes to which injector on each side. How do you tell which is which?
Posted: Sat Aug 29, 2009 4:21 pm
by SLODRIVE
Um, wiring diagram???
You must be tired this morning, lol.
Posted: Sat Aug 29, 2009 4:42 pm
by kimokalihi
Morning? It's night time for me. I'm up late, should have gone to bed an hour ago.
I gotta get off this damn forum. Are the wire colors the same on all the subaru harnesses for the injectors? I'm using an EJ22T harness on an EJ20G/K.
I'll look in the FSM I guess.
Posted: Sat Aug 29, 2009 5:11 pm
by gijonas
If the harness is put on right it should be obvious,due to which side looks dirtier as well as how the wire next to the connectore are bent.
Posted: Sat Aug 29, 2009 7:46 pm
by PhyrraM
This is posted by me somewhere, I will try to find it.
IF the harness is on the manifold correctly (hard to mess up, the main connectors are near the battery)....
THEN the front and rear injector connectors (and coils if going COP) are marked for front/rear cylinders. Front cylinders will have either White tape around the sleeving or have lighter connectors than the rears.
edit....found it.
http://bbs.legacycentral.org/viewtopic. ... 8&start=46
Posted: Sun Aug 30, 2009 12:30 pm
by kimokalihi
Cool, thanks!
Posted: Mon Aug 31, 2009 3:37 am
The 90 harness was actually labeled, 1, 2, 3, 4. Nice feature
Posted: Mon Aug 31, 2009 4:40 am
by wtdash
Legacy777 wrote:The 90 harness was actually labeled, 1, 2, 3, 4. Nice feature
+1!
Posted: Mon Aug 31, 2009 1:05 pm
by kimokalihi
I have 2 EJ22T harnesses here. One is a 92 I believe and the other is a 91. One has the tape on one connector, the other does not.
92 EJ22T
91 EJ22T
