oil pumps?
Posted: Mon Aug 31, 2009 5:32 am
by greg donovan
i think the oilpump on my ej18 is on its way out. can i use oil pumps from other ej motors on it?
thanks
Posted: Mon Aug 31, 2009 7:45 am
by douglas vincent
99.9% sure thats a yes
Posted: Fri Sep 04, 2009 3:33 am
by entirelyturbo
Basically. I know that EJ18s and early EJ22 NAs use the same pump.
In fact, the pump I rebuilt for my car is off the EJ18 motor I had.
Posted: Fri Sep 04, 2009 6:19 am
by BSOD2600
Curious, how'd you come to the conclusion the oil pump is going out?
Posted: Fri Sep 04, 2009 9:12 am
by 93forestpearl
For the pump itself to go out, it would be pretty nasty. A Subaru oil pump will keep pumping until the gears ripped themselves apart.
Posted: Fri Sep 18, 2009 5:14 am
by greg donovan
BSOD2600 wrote:Curious, how'd you come to the conclusion the oil pump is going out?
puking oil when i rev it hard for a while. if i drive it casually no leaking.
however, i am now pretty sure the pump is fine but just needs some screws inside tightened up and loctited so that it stops pushing oil past the crank seal.
Posted: Tue Sep 22, 2009 2:28 pm
by Matt Monson
Greg,
That's probably got a 7mm pump on it. You can upgrade it to either a 9mm NA Ej25 pump or a 10mm Ej205 pump. All oil pumps are interchangeable. I run the 10mm on my 2.5RS.
Pump case blots
Posted: Fri Oct 09, 2009 7:04 pm
by jaybirde508
Greg,
That is a very common issue with the ej engine the bolts/screws backing out on the rotor case/backing plate working there way loose due to vibrations & causing a leak from nowhere?
Great job ,you called it!
Jay
