Transmission questions.
Posted: Fri Sep 04, 2009 10:37 am
The PO decided the car needed 5MT instead of the slushbox(awesome!), but he decided to put an NA transmission in the car instead of a turbo transmission(not awesome), and my clutch is going out(also not awesome), so I'm trying to figure out the best solution to this conundrum, and I have a couple questions.
Will the NA tranny with a new clutch be ok in a turbo? How much power can it handle if I decide to upgrade my engine at all?
And what would be involved in swapping an SS or WRX transmission in? I can find out how to put it in on my own, it's just because of the wiring change from the original swap and mostly going from a cable clutch to hydraulic.
Keeping in mind I am a very poor college student, what would be the best way to go about this? I don't wanna put in another NA clutch if it's just gonna burn out in 6 months. I could probably source a WRX transmission pretty cheap, but it still does cost money...But I'm not sure if I'll be able to find a Turbo transmission at all, or how cheap it would be if I did. It's not completely urgent that I get my clutch swapped out right away, it's just starting to show signs of wear, I had to burn the shit out of it to get going from a stop on a really steep hill, another hill I burned it trying to go up in too high of a gear. Also it grinds going into reverse a lot of the time, and can be kind of "crunchy" going into gear if that makes sense.
I tried searching a bit but I don't really know what to search for since it's kind of a unique situation. It's also 230am and I've been doing HW since 7, so my brain's kind of shut off.
